My order for a koodo post paid connection has been cancelled by saying unable to process your credit card. What should I do next?
  • Updated 4 weeks ago
Photo of Neethu Francis Pulikkal
Posted 1 month ago
Photo of Dinh
Dinh, Mobile Master
  • 45,986 Points 20k badge 2x thumb
hi Neethu,
So did they give out the reason? and what would you like to do next? (getting a phone or a plan?)
You would need the reason and fix it before reapplying.
Photo of David
David, Mobile Master
  • 96,172 Points 50k badge 2x thumb
Make sure the address of your credit card exactly matches that you used on the Koodo order form.
Photo of Dennis
Dennis, Mobile Master
  • 201,104 Points 100k badge 2x thumb
How did they let you know this? Did they give recommendations for a solution?
The koodo mail said, for more information you can contact equifax or transunion directly.
Why it is so? I'm a new credit card user.
Photo of Allan
Allan, Mobile Master
  • 65,658 Points 50k badge 2x thumb
If they're asking you to contact one of those companies then that likely means there is a problem with your credit.
I'd go ahead and contact one of those two companies or your bank and see if you can figure it out.
If you are a new credit card user you may simply not have enough credit built up yet for Koodo to let you purchase a phone.
Thanks for your suggestion
Photo of Dinh
Dinh, Mobile Master
@Neethu: So if they said so, then your credit score wasn't possibly good enough for them (because you are new to the system). If you would like, you could visit a Koodo kiosk and ask the agent there directly. You might also want to have a look at the spending limit program https://www.koodomobile.com/help/spending-limit-program
