My Nexus 4 phone is frozen on update. How do I fix?
Photo of Karen Andress
Karen Andress
Posted 3 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,220 Points 100k badge 2x thumb
Try plugging the phone in and see if the update continues.
Photo of Eugene
Eugene
  • 1,748 Points 1k badge 2x thumb
If your phone froze while in the middle of an update,
1. Restart your phone by holding volume down and power button together
2. When it starts to load push together volume up + volume down + power button - this will run bootloader
3. In bootloader using volume up and volume down buttons pick Recovery mode and push power button
4. After it loaded in recovery mode push power + volume up button
5. Pick wipe data/factory reset
IT WILL REMOVE ALL DATA (photos, videos, whatever) on your phone
Hope this helps:)
Photo of Eugene
Eugene
It will erase all data but I think its worth it to save your phone:)
Photo of Eugene
Eugene
But only do this after you have tried every other option you can possibly think of.
Photo of rikkster
rikkster, Mobile Master
  • 68,252 Points 50k badge 2x thumb
Often when an update fails, the old software remains untouched. If the phone is unresponsive, hold the power button in for seven seconds. This will turn the device off completely. After powering the phone back on, make sure the battery is fully charged and navigate to Settings > About device > Software updates and start the update process again.
A factory reset is a last resort option and should only be used if the phone is completely unresponsive. This method will erase all user data and return the device to a factory default 'first bought' state.
1. If your phone is on, turn it off.
2. Press and hold the Volume Down button and the Power button at the same time until the device turns on. You'll see the word "Start" with an arrow around it.
3. Press the Volume Down button twice to highlight "Recovery mode".
4. Press the Power button to restart into Recovery mode. You'll see an image of an Android robot with a red exclamation mark and the words "No command."
5. While holding down the Power button, press and release the Volume Up button once.
6. Press the Volume Down button twice to highlight "wipe data/factory reset" and press the Power button to select it.
7. Press the Volume Down button seven times to highlight "Yes - erase all user data" and press the Power button to select it.
When complete and the device reboots, make sure you have a fully charged battery before performing the update/upgrade.
Source:
https://support.google.com/nexus/answ...
