My new Samsung Galaxy S3 is problematic in that the battery life ranges between 8 -11 hours, while using minimal functions. Is this normal?
  • 3
  • Updated 2 years ago
Photo of Jim White
Jim White
  • 90 Points 75 badge 2x thumb
  • 3
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,412 Points 100k badge 2x thumb
It is normal depending on how much use you consider minimal and what you are doing. Are you updated to the newest version of Android that has been pushed to that specific device? If not then I highly recommend updating the phone as it helped with battery life quite a bit.
Photo of Decrypter
Decrypter
  • 1,004 Points 1k badge 2x thumb
If your doing all the things mentioned in this article: http://au.ibtimes.com/articles/535287... Then I would say you have a problem. The 8 to 10 hr. time span seems pretty normal. Some people even get less. I've heard of some going 3 hrs. Something to do with the calendar and Android. This guy had a real problem, but managed to solve...hope it helps: https://www.youtube.com/watch?v=0L-7Y...
Photo of Kelly Cooper
Kelly Cooper
  • 60 Points
hi my cell battery will not take a full charge it takes a full day to get hundred percent n drains fast within 5 hours. also my camera is not working. cell is over or almost 2 years old
Photo of Mathieu
Mathieu, Mobile Master
Might just be that you need a new battery, you can easily get one off of amazon or ebay.
