My minutes are going alot faster than I am using them.
  • Updated 2 years ago
I keep buying the 100 minutes and I keep getting the you have less then ten minutes left text when I should still have over half my minutes left
Photo of Roderick Lewis Macleod
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi Roderick,
You can check your minutes as well as usage in self serve. Remember: If you make 30 calls that each take 30 seconds, it will cost 30 minutes, not 15. Also, whenever you check your voicemail messages minutes are still used to do this.
So what your saying is if I call somebody and they don't answer I still get docked a minute?
Photo of Mathieu
If they don't answer then you don't get docked a minute, if their voicemail pickups minutes will start being used. Think of it as a pay phone, if you hang up after 3 rings before the voicemail picked up you get you 0.50$ back, but if the voicemail picks up, your 0.50$ is collected!
Photo of BobTheElectrician
BobTheElectrician
  • 61,918 Points 50k badge 2x thumb
And it's all rounded up to the next full minute. You have to train hard to check your voicemail in under 2 charged minutes.
