My LG GB 255g has started showing a square box with an R icon. What does it mean?
Where can I find a list of icons for the LG GB255g phone?
Photo of Iris Davies
Iris Davies
  • 240 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Sophia
Sophia, Mobile Master
Do you mean in the right hand top corner? Usually that means you're on Roaming. Are you close to the border?
Here is a list of manuals and documents available for that phone, hopefully it'll give you the answer you're looking for :)
http://www.lg.com/ca_en/support-mobil...
Iris Davies
It is in the center/left next to the bluetooth icon. I will double check but I have not had it on roaming. No I am not near the border so I don't have that worry. I've checked the manuals but there are no lists of icons.
Photo of Ahmad
Ahmad
Make sure your phone is actually connected to the Koodo network. If your phones network settings are on automatic, it may connect to a foreign network which could be a reason the R is showing up.
Iris Davies
When I manually choose a network the only networks that show are Telus and Rogers. Could that be the issue?
Photo of Daniel Kim
Daniel Kim, Mobile Master
Select telus, that should work the same as selecting koodo.
Iris Davies
Still have the R
Photo of David
David, Mobile Master
  • 88,508 Points 50k badge 2x thumb
Might be roaming on another network, due to the changes recently enforced by the CRTC to require all carriers to allow roaming on other carriers networks. There should be no cost to you sad long as you are on a Canadian network.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,354 Points 100k badge 2x thumb
Virtual Star
Photo of YDOUTHINK
YDOUTHINK
  • 540 Points 500 badge 2x thumb
So does that mean now I can roam on Rogers towers with this new law you mention? As I visit a friend in northern Ontario. And I get no signal in the past. As only one Rogers tower in the area in question.
Photo of David
That is what is supposed to happen.
