My Koodo SIM Card is not compatible with SAMSUNG S4 phone. Its kind to small for my S4 card slot. What to do?
  • Updated 11 months ago
Photo of praveen
praveen
Posted 11 months ago
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
Did you just buy the sim card? Koodo's sim cards are tri-cut so they are all 3 in one and then you pop out what size you need. If you accidentally popped out the nano size you can try to piece it back together to get a micro size.
If that doesnt work or you just have the nano sim and none of the punch out pieces then you'll have to get a new sim.
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Hey Praveen,
Head over to a Koodo Shop and get a sim. The new postpaid sims now are tri-fit, so make sure not to throw it out because they come with adapters now if you change your phone.
Photo of Goran
Goran, Mobile Master
  • 90,564 Points 50k badge 2x thumb
The break away parts aren't designed to fit together neatly AFAIK. Sure it'll be flat but it's not like they snap into position or keep pieced together. I'd just buy a cheap quality adapter off of eBay or amazon for a buck or two. A few years back I bought a multi adapter kit for a few bucks on amazon.
Photo of Allan
Yea they arent. Theyre meant to snap off and stay that way but if you put it back together carefully you can usually make it work.
