My koodo bill for using hello bollo calling card
  • Updated 2 years ago
I used international calling card from my phone which has koodo connection and I got additional bill of $ 64 from koodo. I have exceeded  free 200 mins it seems. Is it like that? But i was not using Koodo's  service, right ?
Photo of Liz
Liz
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
You could save long distance charge with calling card.
But your are using Koodo's service to make phone calls. So if you used more minutes than included, there will be minutes overage charges.($0.5/min)
You might want to check Koodo's International Long Distance Saver add-on ($3/month)
http://help.koodomobile.com/coverage-long-distance-and-travelling/long-distance
Photo of Liz
Liz
Ok.. Thank you..
Photo of Ivan
Ivan, Mobile Master
Check out Fongo in your app store. It uses data instead of minutes. You can get a free Canadian phone number and call anywhere in Canada for free. This is best used when you're connected to WiFi if your plan doesn't have a lot of data.
Photo of Goran
Goran, Mobile Master
  • 90,810 Points 50k badge 2x thumb
Even with a toll free number, your minutes are still being used as well. As Mayumi said, the add-on might make it cheap enough to use that, or go with Ivan's suggestion of using Fongo. Alternatively you could add unlimited calling or a plan that has it so it doesn't become an issue again if you regularly call overseas.
