My husband has a phone from Hong Kong (they don't lock there) and is now with Bell. How easy is it to keep his number and migrate to Koodo?
  • Updated 3 months ago
My husband has an Android phone from Hong Kong (they don't lock things there) and is currently serviced by BBell. How easy is it to keep his number and migrate to Koodo?
Photo of Daphne Symeonides
Daphne Symeonides
Posted 3 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
If the phone works on Bell it will work with koodo as they use the same towers. Just visit your local Koodo kiosk and tell them you'd like to port your number over to Koodo and they'll get you all set up with a plan. Make sure to not cancel your bell service this will be cancelled automatically when you transfer the number to Koodo and you will the n get a final bill from bell.
Photo of Allan
Allan, Mobile Master
  • 57,086 Points 50k badge 2x thumb
If you or someone you know is with Koodo you can take advantage if the $100 referral offer if you activate online instead.
https://referafriend.koodomobile.com/...
Otherwise Paul's suggestion will work easily and just fine.
