my gmail app is very slow; it seems like it won't load, and then it loads a few minutes later
  • Updated 1 year ago
Samsung Galaxy S4
Photo of Catherine Climpson
Catherine Climpson
Posted 1 year ago
Photo of Robert
Robert, Mobile Master
  • 106,846 Points 100k badge 2x thumb
Hello Catherine,
Try uninstalling and re-installing the app to see if it solves the problem.
Photo of Allan
Allan, Mobile Master
  • 62,140 Points 50k badge 2x thumb
Does the app take a long timr to load or the emails? Do your other apps take a long time as well?
Catherine Climpson
The e-mails take a long time to load; someone suggested that I uninstall and reinstall it; so I will see.
Photo of David
David, Mobile Master
Sometimes just restarting your phone helps to 'clear its memory'.
Photo of Jru Gordon
Jru Gordon
  • 9,144 Points 5k badge 2x thumb
also you could go into your Settings, Storage, see what the apps are using, and clear your Cached Data and the Saved Data (might not be exact terms) for both the phone and your email app.
Photo of Allan
Do web pages take a long time to load as well? It could be possible that you are currently using a slow internet connection.
