My data won't work on my LG G4. I'm using the Network mode: GSM/WCDMA/LTE. Would I need to set up a specific APN? or Network operator?
  • Updated 1 year ago
Hi folks. My data won't work on my LG G4. I'm using the Network mode: GSM/WCDMA/LTE auto. Would I need to set up a specific APN? or Network operator? Living in Nelson BC.
Photo of Cole Auringer
Cole Auringer
Posted 1 year ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,580 Points 100k badge 2x thumb
Yeah here is koodo APN
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save. Make sure the radio button is selected to activate data. The frequencies are compatible so it should work
And choose Koodo as network operators and make sure your data is enabled in settings under data usage
Photo of Goran
Goran, Mobile Master
  • 90,800 Points 50k badge 2x thumb
Did you just get your g4 from a different carrier or is it with Koodo? Did you just sign up with Koodo or is it something that randomly stopped working?
Photo of Wang Chain
Wang Chain
Switch to "LTE" in the case of 4G internet connection and then again search for networks and choose auto network selection. Hope that works.
