My BLU Android phone doesn't ring when I get a call? All other notifications make a sound?
  • Updated 1 year ago
I've tried adjusting all my Settings, but nothing seems to work.  It's only an issue when I receive an actual telephone call.
Photo of Paula
Paula
  • 202 Points 100 badge 2x thumb
Posted 1 year ago
Have you made sure priority mode is off?
Which BLU do you have?
Photo of Paula
Paula
I have a Life 1x2 - Android 6.0.1
Photo of Paula
Paula
I think my priority setting is off. This is my first smartphone. The operator is not so smart.
Photo of Paula
Paula
Oop, my telephone ringer is working now!
Thanks for your help!
Photo of DJ
DJ
  • 792 Points 500 badge 2x thumb
You say you don't use a carrier. You only use voip. I would check that it might be voip causing the problem and not the phone or another app.
Photo of Paula
Paula
No, I use the Telus network.
Photo of David
David, Mobile Master
  • 88,508 Points 50k badge 2x thumb
You can make & receive calls?  It just does not ring?
Photo of Paula
Paula
Yes, I can make calls.  And if I happen to be looking at my phone & see a message indicating that someone is phoning me I can answer it.
Photo of Allan
Allan, Mobile Master
  • 61,840 Points 50k badge 2x thumb
Do you have Bluetooth or do not disturb turned on? Is the ring volume down? Some phones have different volume settings so you can have the volume up for notfications and everything else but down for your ringer.
Photo of Paula
Paula
Yup, I have media, alarm & ring volumes all set at maximum.
Photo of Paula
Paula
No, Bluetooth & Do Not Disturb are turned off.
What about priority mode?
Do you have a ring tone set?
Photo of Paula
Paula
Yes, I set a ring tone.
Just tested it by phoning from my land line & it's ringing!
Photo of Paula
Paula
Good news - my telephone ringer is working now!
Not sure what did the trick because I investigated all your suggestions & rejigged a number of things.  Thanks for all your respones - much appreciated!
Photo of David
  • 90,590 Points 50k badge 2x thumb
YAY!  Thanks for updating the community with your success.
