My Bell Satellite TV currently plugs into landline. Will it work with Koodo home phone hub?
  • Updated 2 months ago
The satellite receiver uses a phone line for certain functions (call display on tv and ordering pay per view). Can I use second jack on Koodo Home phone gadget to plug in TV Satellite receiver. Will Satellite work with cell instead of landline?
Photo of janet
janet
  • 232 Points 100 badge 2x thumb
Posted 3 months ago
Photo of Goran
Goran, Mobile Master
  • 90,970 Points 50k badge 2x thumb
Hmm that's a good question. You can check the manual to see if theres a thing about it. Or just try it and see if it does work?
Photo of janet
janet
Well - want to kill landline at same time....is there a link to the manual?
Thanks for your help.
Photo of janet
janet
Ok - think I found the manual but it does not mention this issue.
Photo of David
David, Mobile Master
  • 89,300 Points 50k badge 2x thumb
Fax is not guaranteed to work with the WHP hub, and some folks have had difficulty with alarm systems. Might be the same with this cellular device.
Photo of janet
janet
Thanks for that information.
Photo of BobTheElectrician
BobTheElectrician
  • 62,114 Points 50k badge 2x thumb
Shaw Direct satellite does not require an on-line phone connection to order pay-per-view or stream online. Of course, you won't have on-screen call display.
http://www.shawdirect.ca/english/support/article/8334/
http://support.bell.ca/TV/Receivers/How_to_order_Pay_per_view_on_my_Bell_TV
Photo of Tracey T.
Tracey T.
  • 104 Points 100 badge 2x thumb
Not sure I understand any of these responses to Janet. Does a satellite run through the original Bell lines as if the house does not have a phone?
Photo of Allan
Allan, Mobile Master
  • 55,974 Points 50k badge 2x thumb
The satellite tv has a phone jack that allows you to get call display on your tv.
BobTheElectrician
You can order the home phone service with a temporary number and try it out. If it works, port your regular number over. Otherwise, return it during the grace period. The phone rates are nothing to sneeze at. If some minor features with Bell don 't work, you can then judge the trade-off for yourself.
Photo of janet
janet
I am writing to definitively answer my own question in case someone has the same question in the future. I had two lines in my house so decided to try moving one to Koodo home phone service to see how well it worked. I am happy to report that my Bell 9242 Satellite TV works fine with the Koodo service. The call display shows up on the tv and I am able to order pay items seamlessly. Am happy with the Koodo home phone service and will be switching my other land line soon. If anything the sound on calls is clearer than my land line. It works great with my existing phone handset. Happy customer so far....
BobTheElectrician
  • 61,502 Points 50k badge 2x thumb
Thanks for reporting back to the community.
Photo of janet
janet
One more thing - for the caller ID to show up on the TV it seems as though the satellite box has to plug into the Phone 1 jack on the Koodo box, then home phone can go in Phone 2 Jack. If reversed I don’t think caller ID was displaying on TV. Not sure why. But seemed to work when I switched jacks.
