My battery doesn.t seem to hold a charge. How long have I had my phone?
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 611 mentions
Photo of Sandra Grills
Sandra Grills
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of rikkster
rikkster, Mobile Master
  • 68,326 Points 50k badge 2x thumb
If you've had your phone for less than a year, battery replacement is covered by the manufacturers warranty. If the phone is more than a year old and has a removable battery, you can probably find a replacement battery online. If the battery is non-removable, it will have to be sent in for service. To find out how long you've had your phone or if you want information for warranty purposes, dial 611 and ask when the phone was purchased.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,504 Points 100k badge 2x thumb
Or log into your self serve account and look under tab and you should be able to see when you purchased your phone if you put it on a tab, just look for the large negative amount and that's the date you purchased your device.
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hello Sandra,
Were you able to find out if your phone is still covered by the warranty?
Keep us posted :)
