Moving for school will my phone plan still be suitable for my needs?
I am not sure if I have to change my plan, right now I live in Toronto and have the 15$ prepaid plan with a few boosters like data and add on minutes.
I might go to school in hamilton in Fall of 2016. Can I still use my current plan in hamilton, are there any extra charges I should be aware of?
Here is the link to my plan: http://koodomobile.com/en/on/plansand...
I don't know if the texting, minutes, and data are okay to use for Hamilton (still in Ontario) or if i should look at another plan
Thank you.
Photo of Lula
Lula
  • 366 Points 250 badge 2x thumb
Photo of Dennis
Dennis, Mobile Master
  • 196,120 Points 100k badge 2x thumb
Hi Lula,
Everything should still be good for you to use. No change is required.
The only thing is that you will have a Toronto phone number which may cause your new Hamilton friends a bit of grief if they want to call you and have to pay long distance to call a Toronto number (unless they have canada wide minutes too)
Photo of Sophia
Sophia, Mobile Master
It's free to change your number though and still keep the same plan :) Just thought I'd add that - you can change your number as often as you like in self service.
Unless you start using way more minutes or data, you won't need to change.
