Morphed voices On roaming
Can I do anything about the voices being morphed and garbled on my Samsung sgh-t989d? Just purchased the 10 day roaming plan, but can't seem to hear any voices clearly?!
Photo of Kelly Parker
Kelly Parker
Posted 3 years ago
  • 203,644 Points 100k badge 2x thumb
I had the same issue With mine, unfortunately that phone doesn't play nice with AT&T.
The only fix that works is to shut it down and remove both the battery and SIM for a full minute and then put everything back together.
To fix it you'd need to root the device and flash the t-mobile radio, but doing so would void your warranty.
