Mobile data worked on IPhone but not Samsung Note 3?
I previously had an iPhone 5s, and switched sim cards to a Samsung Note 3, however, for some reason I am not able to go on mobile data with the Note 3. I'm wondering if this is because the data is specific to my iPhone, or possibly Koodo doesn't support that phone (since I don't see it in the phones category). Please help!
Photo of Jasmine S
Jasmine S
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
Apple is not same software if you are receiving this error may do to software tray reset your phone
if that doesn't work tray hard ware reset if nothing
your phone my need a flash
I hope this help please remember is like computer
Here app may help you clean master
Photo of BobTheElectrician
BobTheElectrician
  • 61,888 Points 50k badge 2x thumb
Check your APN
http://aide.koodomobile.com/Portals/0...
You may have to 6-1-1 Koodo to make sure your imei (phone serial number) is registered for data. Just swapping a SIM often works for voice/text but you won't get data until it is enabled by the mothership.
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Robert, unless you have data blocked, data is always enabled :) Thank you for your help!
Photo of Jasmine S
Jasmine S
That's awesome Robert! Thank you! Inputed all that and got my mobile data up and running :)
