Mobile Data not working
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
Hi, I have bought a Koodo prepaid line a month ago, I used it with my mobile (HTC m8) and it was working good. Now I am using different mobile but the same model (HTC m8). It can't operate the mobile data whenever I switch on the Mobile Data, It says "Disconnected". I tried to use it in different location but nothing different
Photo of Ahmed Tarek Fahmy
Ahmed Tarek Fahmy
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Ray
Ray
  • 7,756 Points 5k badge 2x thumb
Also, if after checking the APN's and correcting them if necessary, do you still have some data left in your Data Booster?
Ahmed Tarek Fahmy
I have correct APN setting, My phone is working good in calls and texting and I still have 683 MB remaining in my data booster
Photo of Ray
Ray
Can you try restarting your phone in safe mode? If it works, you may have an app installed that is causing a problem.
Failing that, can you try another SIM?
Ahmed Tarek Fahmy
I tried booting in safe mode, but the same problem occurs
Photo of Yannick
Yannick
Hi Ahmed, are you still having issues with data? If yes, don't hesitate to contact our technical support at 1-866-995-6636 form another phone, option #6 (free call). We'll do our best to help :)
