mobile data not working
  • Updated 3 weeks ago
Hello, I have a Galaxy S7 with prepaid Koodo plan.  I was able to receive texts until recently but now I cannot.  I can use wifi with email, internet and mysms app and Hangouts app.  When checking SIM card status, it says: Network: Unknown, Mobile network type: Unknown, Service state: Radio off, Roaming: Not roaming, Mobile network state: Disconnected.  I have checked the APN to make sure it matches with other posts here and it does (no need to change).
I am thinking about buying another prepaid sim card...
Thanks in advance!
Photo of Mike P
Mike P
  • 80 Points 75 badge 2x thumb
Posted 3 weeks ago
Photo of Mike P
Mike P
Sorry, I do not have a 'Plan', rather just a prepaid - pay as you go.  thanks
Photo of Dinh
Dinh, Mobile Master
  • 42,890 Points 20k badge 2x thumb
Hi Mike,
Have you check your selfserve and see if your number was active?
I would also try to restart the phone and reset the network settings and see if it helps.
Photo of David
David, Mobile Master
  • 94,536 Points 50k badge 2x thumb
Is your base plan current? You need to have at least the $15 base plan active.
