MMS Problems
  • 2
When receiving a mms the picture is removed and replaced with "Content was removed because your handset cannot display it." Iphone 5 on ios 7, tried resetting network settings but no luck.
Photo of adam baxter
adam baxter
  • 2
Photo of Daniel Kim
Daniel Kim, Mobile Master
It could be the size of the pic? try having them resize the (at lower resolution) pic and sending it again.
Photo of Xavier
Xavier
  • 7,610 Points 5k badge 2x thumb
Silly question, did you ever installed Onavo?
If resetting the network corrected the problem once chances are its a network problem. If it was an issue with your phone resetting the network would not have done anything.
You can double check your iPhone by going to Settings> Messages and insure the MMS Messaging is set to ON
adam baxter
It is a pic from an iphone so size shouldn't be a problem.
I did install onavo data manager for a few minutes last night, but have since deleted it. Is there a known issue with that app?
I'm not positive, but. I don't think it's my phone. It's only a few months old and has pic msgs have worked right up untill yesterday.
Photo of Xavier
Xavier
I had same issue with an iphone I had. I had Onavo at one point, but deleted it. I had forgot that it installs a "profile" onto your phone. I found the only way to completly delete onavo was to follow these steps and delete the profile they installed.
Goto your iPhone's Settings -> General -> Profiles
Locate the Onavo profile
Tap 'Remove'
If you EVER had Onavo installed you need to follow these steps!! Fixed it for me!! Hope it helps!!
Photo of Xavier
Xavier
BTW, did it just started today?
You can still send pictures, can't you?
Photo of Tracy Hachey
Tracy Hachey
Mine started the same thing yesterday!!! I can't send or receive mms!!! I've always been able to!!!
Photo of Xavier
Xavier
How bad Tracy. Follow the steps above. We are investigating the issue. Seems some other user are having the same issue. You are not the only one. Once i have news we will let you know.
adam baxter
Xavier, I don't have a profiles option in settings > general, so I guess that means I don't have a profile installed.
Tracy, I can't send mms to other koodo customers, but other carriers seem to work (Rogers does for sure). I cannot recieve mms from any carrier though.
Photo of Myke
Myke
This is a known issue right now. Koodo is aware of it and is looking into a fix. Should be resolved in 72 hours, but may take longer than that.
