MMS On Z10 Still Not Working
I have called Tech Support and they were unable to help at. All they told me was maybe the next update may fix it. I've already updated my software twice since then. I have also done a battery pull, remove SIM card and all the other normal stuff. I have also tried playing with the advance settings for MMS and still nothing
Any ideas?
Z10STL100-3/10.2.0.1803
Photo of BluWolfy
BluWolfy
  • 644 Points 500 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
What type of MMS problems? The picture you showed is a Google picture, so I'm a bit puzzled what you are referring to.
What plan are you on, and what exactly is not working, sending MMS messages or receiving, them, or???
Is the recipient by any chance a google number or a voip service number. Its the only time ive had that happen to me.
Photo of Ry
Ry
  • 5,552 Points 5k badge 2x thumb
In the Hub, go to Settings. Tap Text Messages, then tap Advanced at the bottom.
Scroll down, what does your mmsc show?
Should look like attached.
Photo of BluWolfy
BluWolfy
Thx Ry!!!!! That did the trick! Awesome :D
@Sophia That was a picture of the Google website that I tried to send. Just took a screen shot of the website to have a picture to send to show the error
@Chad Burr The recipient was myself actually
Photo of Ry
Ry
Excellent, glad you are up and running!
