MMS not working after APN is set up
  • 2
I have a Nexus 4 bought from Google and have data, and MMS. I"ve changed my APN settings multiple times. I currently am using the ones Koodo has posted. I've also tried using the "MMS ALLOW" APN.
Photo of Govind Gupta
Govind Gupta
  • 2
Photo of Dennis
Dennis, Mobile Master
  • 187,758 Points 100k badge 2x thumb
Is cellular data turned on? MMS Uses cellular data. It wont work on wifi
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
Back in my Telus days (on an LG eXpo (IQ in Canada), no less), I faced a similar issue. MMS's wouldn't work. I called in and the agent basically "flushed" my SMS/MMS queue on my account because apparently, one was "stuck" there and kept the other ones from going through. I could neither send nor receive. But, although I was skeptical, it did work correctly after the rep did his thing. It's the only time such a thing ever happened to me, and it never happened since I joined Koodo. So Govind, you may want to call *611 and ask them to check out your account.
Govind Gupta
Thanks I'll call them tomorrow!
Photo of Dennis
I also assume yor regular SMS works?
At this point I would advise calling Koodo tmrw morning 1-866-995-6636 as it could be something on their end
Yes, I forgot to point out that while MMS's were stuck, my SMS's functioned normally.
Actually, I could receive the "text" part of MMS's sent to me, only the multimedia content wouldn't go through (yes, data was enabled and active). It worked correctly after that call to C.S.
