MMS not being sent!
My MMS isnt working. Now I know this has been asked before, and I did check all I can for the solution but nothing works. I checked the APN settings, they're all right as rain, I can recieve but I cant seem to send. Im using an unlocked Galaxy S2. Whenever I send a picture, it just says sending and stays there. I got an unlimited MMS and Text plan, as well as 2 GB of data.
Help?
Photo of Christian Boukhater
Christian Boukhater
  • Upset.
Photo of Starfox
Starfox
  • 5,718 Points 5k badge 2x thumb
Are you connected to wifi?
Christian Boukhater
yep. I tried both connected to Wifi and disconnected from it. With data and without data. nothing really worked
Photo of Starfox
Starfox
Hmm...well since you already mentioned the APNs are right, you have tried using mobile data which picture messaging only works on, well not in the case...
Is this what your apn details look like?
APN: sp.koodo.com
Proxy server: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http://aliasredirect.net/proxy/koodo/...
Port: 80
MCC: 302
MNC: 220
Authentication type: None
APN type: leave blank
Data set-up
Picture messaging will not work on wifi
Photo of Starfox
Starfox
Then tech support will have to troubleshoot. One thing that worked for me when I had to call on my cell is the agent mentioned they would exhaust all the resources for the issue until the point of having to turn the phone off or w.e. The agent did offer to call me back after about 5 minutes which he did to avoid me having to call and get a new agent and we were able to move forward. In the end, my issue was resolved. Give that a shot if you want andhopes that the agent will give you the same experience I received when I called.
If you are told they cannot call you back, they are not the right person to speak to. the agent I spoke with did NOT mention to me that not all agents will be able to offer a callback. From what I understand, If it is within 5 minutes, they can call back
Christian Boukhater
I'll try and borrow my friend's phone tonight. Less of a headache, lol. Thanks a bunch
Photo of Starfox
Starfox
No problem. I hope it all works out for you
if you have any other APN listed besides Koodo.sp delete it then reboot the phone
Christian Boukhater
oh wow. That worked. didnt think it would matter. Thanks a lot!
Photo of Cassy P
Cassy P
hi, so i was on another forum and they suggested i change the APN type from 'default,mms,supl,dun' to 'internet + MMS'. I tried it and it worked! The other info i kept the same, the only thing i changed was the APN type. I hope this helps!
