MMS load for ever
When I try to look my MMS messages, it's loading but it doesn't stop, It's been loading for over an hour now, so what should I do
Photo of Joël Chamberland
Joël Chamberland
Photo of Erwin
Erwin
  • 23,576 Points 20k badge 2x thumb
Hello Joel,
What phone are you using? and have you received MMS before?
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
Did you pull out the battery out ?
The problem could be with the MMS application.
If it is an adroid phone, do following
got settings > application > look for SMS application , then force it to stop .
Joël Chamberland
What i do after force it to stop
Photo of MatB
MatB
  • 32,478 Points 20k badge 2x thumb
That happens usually when your phone is trying to download picture because it needs 3G connection, if Data is not enabled it won't. Turn phone off/on, test internet browser, send an MMS test to yourself to find out if it works.
Joël Chamberland
I used HTC One V,
i close it than reopen,
restart,
put it on charge,
remove card.
i do receive messages and no photos since yesterday
Photo of MatB
MatB
That message was received when your phone did not have Data enabled, ask your sender to send it back, if you can browse you'll be able to download it
Joël Chamberland
yeah but its loading, i know i received, but cant answer ou read it...
Joël Chamberland
Oh I can can receive/make call
Joël Chamberland
up please need help
Photo of MatB
MatB
If Data is not enabled and your received attached pciture with text message, pciture does not get into your phone - you can only read message but not picture.
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Hey Joël,
Data services must be enabled on your device and on your account to be able to send/receive picture messages.
If a data block has been applied on your account, you can simply log into your Self Serve to remove it from the features list.
If data is blocked on your HTC, you can remove it from the device:
Go to: Settings/More/Mobile Network to enable data.
If you still need help please give us a call at 1-866-995-6636 from a landline and select the 6th option, a rep from Tech Support will assist you further.
Our hours of operation are:
Monday – Friday: 9am - 9pm
Saturday: 9am - 7pm
Sunday: 9am - 7pm
Hope this helps!
