Mms not working
  • 2
  • Updated 3 months ago
I have a Samsung Galaxy 6 - had it almost a year. Suddenly my MMS messages won't download. There's no error message. It just tries for about 30 seconds then stops. I am using data and checked the APN.
Photo of Jaime Kawamoto
Jaime Kawamoto
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
  • 2
Photo of rikkster
rikkster, Mobile Master
  • 68,302 Points 50k badge 2x thumb
Try resetting network settings. This procedure will reset all network settings including those for Wi-Fi, mobile data and Bluetooth. Go to: Settings > Backup and reset - scroll down to and tap on Reset network settings. Tap RESET SETTINGS, if you have a password protected phone, you'll be prompted to enter the password. Once entered, tap RESET SETTINGS. Let us know if this resolves the MMS download problem.
Photo of Sunspot
Sunspot
  • 160 Points 100 badge 2x thumb
I have had the same problem for the last four months since I changed to Koodo and I tried everything listed in this thread, but nothing worked.
Now I finally found a solution, and it is pretty simple. In APN Type mark default,mms,supl save it and reboot the device.
I hope that will help someone as it helped me!
