MMS not supported by network
  • Updated 1 year ago
Have Samsung S7 with nougat update. Plan unlimited sms/talk 1 go data. Mms (pics) not supported by network. How do I fix it?
Photo of Mico
Mico
Posted 1 year ago
Photo of Dennis
Dennis, Mobile Master
  • 195,870 Points 100k badge 2x thumb
Try restarting your phone.
Does your cellular data work?
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
Confirm that your APN settings are still good. Reset your APN if it still isn't working.
Photo of Mico
Mico
Restarting the phone does nothing. How do I know my APN settings are still good and how do I reset? Sorry guys, not very tech savvy.
Photo of Dennis
  • 195,596 Points 100k badge 2x thumb
Here is what the APN settings should be
APN: sp.koodo.com
Proxy: leave blank
Port: leave blank
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: None
APN type: default, mms
Setting > Connections > Mobile Networks > Access Point Names > ... >  Reset to Default
Photo of Mico
Mico
I already have all of the above under EDIT ACCESS POINT on my phone. But I just noticed that scrolling down there is "Enable/disable APN" button in light grey that I cannot switch on or off.
Photo of Dennis
Does regular data work?
Photo of Mico
Mico
Yes everything works except sending pics.
Photo of Dennis
What messaging app are you using?
Photo of Mico
Mico
I have 2 in default messaging apps: MobileGo and Messages. Messages is the one that was ticked off when I purchased the phone.
Photo of Dennis
As a test, can you download Textra and see if it work?
You can uninstall it at anytime
Photo of Mico
Mico
Both Textra and MobileGo "want to take my messaging over" and Samsung warns me that some functions will no longer work and it will not be responsible for errors. I have sent pics before; is it possible that it's a "today thing" ?
Photo of Dennis
I would allow Textra to take things over.  you can uninstall it later if you choose to.
I have no problem sending mms so it does not seem to be a network wide issue
Photo of Mico
Mico
Thank you for all your help! I will let you know.
