MMS not fully working
Hey guys. I recently switched over from telus to Koodo, and now my Samsung s3 is no longer sending mms messages. It can receive them though. I'm pretty sure I have all the apn settings right, and my mobile data is turned on, so I'm not sure whats up? Why would I be able to receive, but not send mms?
Photo of Reuben  Brouwer
Reuben Brouwer
Posted 3 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,714 Points 50k badge 2x thumb
1. Settings=>More networks=>Mobile networks=> make sure Mobile data is checked (you've already done this).
2. In the same window, Network mode => LTE/WCDMA/GSM should be selected. You can toggle between the first 2 values and re-start your phone. Sometimes this will fix connection problems.
3. double check APN settings:
http://aide.koodomobile.com/Portals/0...
4. Settings=>More networks=>Mobile networks=>Network operators (it may take some time to scan all available networks)=>Choose “Select automatically”
Re-start the phone, preferably by removing the battery for a few minutes.
Photo of Dennis
Dennis, Mobile Master
  • 196,890 Points 100k badge 2x thumb
Reuben Brouwer
Thanks for the help.
I think I've tried it all fellas. Nothing seems to be working.
Photo of Dennis
Maybe it's time for a backup and factory reset?
BobTheElectrician
APN settings: change APN type from blanks to "default,mms,supl" with no quotes or spaces. This solved a trick with another carrier.
App settings => Messaging => Clear cache & clear data -- worth a try.
You will most likely lose all your messages, but less drastic than factory reset.
Another option: try another messaging app such as Hangouts. If the problem persists, then it's really a connection issue.
