MMS Help / Data Block
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 611 "press 0" mention
Hello, I have the 30$ plan but I cant use MMS. I have data block on and I need to turn it off. I understand I need to turn all my settings to Wifi only but I only need to know how to turn of data block. If you can help that would be great thanks.
Photo of Keaton Woods
Keaton Woods
Posted 3 years ago
Photo of RudyW
RudyW
If you have data block that is on your account. Log in online go the the change add on section and you can remove it there.
Keaton Woods
I think the self serve part of the website is broken at the moment. I cannot login
Photo of Mayumi
Mayumi, Mobile Master
  • 115,066 Points 100k badge 2x thumb
If you can't login, you will need to call Koodo *611 from your phone.
Tell them you tried to remove " Data Block add-on" via self serve, but you couldn't access/log into it.
Keaton Woods
Okay, thanks.
