Mismatch between Data Usage alert and bill. What to do? How to challenge billing?
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: SS App mentions
I received an SMS from Koodo at 5:54 saying I've used 95% of my Data plan. So I completely stopped using the Data plan until the end of the billing cycle.
Then the bill came with surprises... The Data Usage report online says I used 2MB above my limit. But all the usage reported is logged before 5:45, I mean 9 minutes before Koodo alerted me. How come is this possible? How can they say that I've used 95% of my plan, but then show different calculations in my invoice?
What should I do? How can I challenge this billing calculation. I still have the message on the phone.
Photo of Adal
Adal
Photo of Dennis
Dennis, Mobile Master
  • 187,616 Points 100k badge 2x thumb
There could be a delay. However if you call into Koodo and calmly explain your confusion they may credit you the overage charge at their discretion. No promises though.
Photo of Adal
Adal
The OS is Android 2.3.4.
There are too many apps for what I need. I just wanted to try the best ones...
I do keep track of my consumption. I have the SelfServe app installed and like it a lot. But the 95% consumption alert was not reliable, at least not in my case, and this is the first time I ever reach it.
I will try 3G Watchdog per Koodo's suggestions in http://help.koodomobile.com/plans-add...
My problem with 3rd party apps is that are meaningless to Koodo, it is their tracking what matters in terms of billing and limits. Although better alerts might be the best advantage here.
Thanks again.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
When using other methods for data tracking, make sure you set the dates to match your bill cycle. More often than not, that is the case with data disputes. The usage chart in the app/phone has a different set of dates than the actual billing period.
Photo of Adal
Adal
I've been monitoring the Data Usage report online and indeed they have a considerable delay of at least of two hours. I mean, it takes hours for your data consumption to appear on the report. And apparently also their alerts work the same way, that might have been the reason why I got my alert too late. (which IMHO makes the alerts kind of "unreliable")
I emailed the customer service about this issue and I'm waiting for response. I'll keep this post updated once I have news.
Thank you all
Photo of Adal
Adal
They fixed the problem. I was not charged the overconsumption.
In addition I have noticed there are always mistmaches between 3G Watchdog and Koodo (Online report and SelfServe)
Zaphod Beeblebrox
Make sure the 3g watchdog is set to match your bill cycle. 3g watchdog does operate on somewhat real-time while Koodo has a few hour delay.
