Minutes used not showing up on usage
I recently switched from Telus to Koodo. I've made several phone calls, but it's not showing up on my usage?
Photo of Chanse Morrell
Chanse Morrell
  • 102 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Yannick
Yannick
Hi Chanse, can you give us more details? Do you mean that you can't see the calls in the usage summary section of your Self Serve account? Thank you!
________________________
Chanse Morrell
Yes, that is exactly what I mean. Also, I've set up the APN for koodo, but my data usage isn't showing up either, and I cannot send or receive picture messages.
Photo of Mathieu Carrier
Mathieu Carrier
  • 4,124 Points 4k badge 2x thumb
If you just created your account then it will take a few hours/days to see your usage summary be updated in your sefl serve :)
Photo of BobTheElectrician
BobTheElectrician
  • 67,578 Points 50k badge 2x thumb
Judging from your posts, it's been 7 days or so since you switched, well beyond the grace period for normal software migration.
Can you make calls? Try calling & texting yourself. This will establish whether basic service exists.
APN only refers to data.
Take the phone apart as far as you can easily. SIM removed, battery removed?, then wait a half hour. Reassemble and try again.
Chanse Morrell
I can definitely use service and data I have no problem calling and texting, but like I said, only my texts are showing up on my usage under my koodo account.
BobTheElectrician
Time to deal with *611 then.
*611 / 1-866-995-6636 / 647-788-4337
Wouldn't want to suggest waiting a few months to see if billing actually sees the same...
Chanse Morrell
Actually, I think this might be an issue with the app? When I go to the website, it also shows zero usage, but then when I click history, it shows my usage properly
BobTheElectrician
Website currently screwed up on a lot of fronts.
