mi max 2 on koodo network
  • Updated 10 months ago
Just wondering if the Mi Max 2 will work on the Koodo network?  It isn't listed on willmyphonework.net
Specs:
Xiaomi Max 2 4G Smartphone Specs:ModelXiaomi Mi Max 2Band2G: GSM: B2,B3,B5,B8; CDMA1X / EVDO: BC0
3G: WCDMA B1, B2, B5, B8; TD-SCDMA: B34, B39; CDMA EVDO BC0
4G: FDD-LTE B1/B3/B5/B7/B8; TD-LTE: B38, B39, B40, B41
Photo of sean
sean
  • 230 Points 100 badge 2x thumb
  • confused
Posted 11 months ago
Photo of Dennis
Dennis, Mobile Master
  • 187,758 Points 100k badge 2x thumb
The Max 2 uses:
3G HSPA+ 850 / 900 / 1900 / 2100
4G LTE band 1(2100), 3(1800), 5(850), 7(2600), 8(900), 38(2600), 39(1900), 40(2300), 41(2500)
Koodo uses
3G HSPA+ 850/1900
4G LTE 1700/2100
So it will work on 3G, but not 4G LTE
Photo of sean
sean
Thanks for the info. Saw it on banggood - in stock in a few days. There are a couple of top sellers (one in US) on eBay that have it too - just have to make sure it is that global version. I don't do that much on the phones cell network anyway -mostly on wifi at work and home and only occasional calls. Hopefully it works out. I'll let you know how it turns out, if I can make my mind up on a seller...
Photo of Ivan
Ivan, Mobile Master
I'm using a Xiaomi Mi Note 2 and get LTE-A.
Photo of sean
sean
Nice. Do you mind me asking where you got it from? Weighing my internet buying options still
Photo of sean
sean
Ended up getting a (barely) used Nexus 6P from someone locally...
Photo of Goran
Goran, Mobile Master
  • 91,316 Points 50k badge 2x thumb
I hope that it serves you well! Don't hesitate to come back if you need help with anything else.
