Lte vs Wcdma reception
  • Updated 1 month ago
Hey guys, I recently signed up with Koodo, and I've found that when my phone (s8) is set to lte/wcdma/gsm auto, it always sets fo Lte, and I get 1-2 bars of reception everywhere, sometimes 3(I live in the west island of Montreal). If I manually set it to Wcdma or gsm, my reception shoots up to 4-5 bars in the same locations, and data switches to 4g.
Is there a huge difference between lte and 4g? Would I be better sticking with Wcdma for the better reception? I know everyone always talks about lte being the newest or best ....
Photo of Matt
Matt
  • 80 Points 75 badge 2x thumb
  • Confused
Posted 1 month ago
Photo of Dinh
Dinh, Mobile Master
  • 41,904 Points 20k badge 2x thumb
Hi Matt,
I would keep it to Auro with the S8. The phone will automatically choose the right network for you. Regarding your question, wcdma is 3G. LTE is better for data. I believe your phone will automatically switch to 3g/wcdma when calling.
Photo of Matt
Matt
Really? When I switch to Wcdma my data icon says "4G".
Ive had it on auto the past week, but have noticed my signal bar is always 1-3, just switched it to Wcdma last night and Havnt seen lower than 4.
Photo of Dinh
Dinh, Mobile Master
  • 37,098 Points 20k badge 2x thumb
WCDMA is  3G https://www.gsma.com/aboutus/gsm-technology/3gwcdma
Koodo/Telus is using multiple bands for their cell signals. The phone should know automatically how to choose the best bands for you. When the LTE signal is weak, they normally fall back to WCDMA/3G. You could try to do a speedtest to see how fast can you go with LTE and CWDMA. Noted that each speedtest would take away 100-120MB of your data.
Photo of Allan
Allan, Mobile Master
  • 59,296 Points 50k badge 2x thumb
Unless you're having problems just keep it the way it is.
As long as you have something and it's not affecting your phone usage it really doesnt matter if its 5 or 1 bar.
Photo of Dennis
Dennis, Mobile Master
  • 191,066 Points 100k badge 2x thumb
It's a marketing thing.
WCDMA = HSPA+
Which is what I personally call 3.5G
It is faster than the initial 3G but it is technically not 4G.  Customers got suckered in with the G's to determine better networks so companies started calling 3.5G as 4G
LTE is officially 4G
I also echo what Allan said.  If you have no reception or connection issue then leave it on LTE.  If you are noticing the 1 and 2 bars are impacting you getting network connection, then switch to WCDMA.
Note that LTE is only used for data. Voice and text will be on WCDMA
Photo of koimr1
koimr1
  • 198 Points 100 badge 2x thumb
If it helps any I've also noticed a difference with 3G/wcdma/hspa+ having more bars than 4G/LTE but even with a lower signal the speed is still higher with the latter. Your mileage may vary, of course. :)
Photo of BobTheElectrician
BobTheElectrician
  • 64,402 Points 50k badge 2x thumb
The bars you see can be largely misleading. If you download a PlayStore utility like Signal Strength, you can get actual numbers for your reception in real time for both networks, as well as an indication of how useful that signal is. It's not unusual to see 2 bars be shown when the signal is just marginal, as well as when it's just fine.
Montreal's West Island has a few cellular black holes mixed in to areas with excellent reception. It's the same for all carriers. As long as your calls are OK and data is working fine, I would just call it a day and move on to something else. It may be amusing to watch the signal meter flicker up and down (it won't be all that stable, since cell signals are weak). But it's something that we can't control or improve.
