LTE rececption
I have an unlocked LG G2 on Koodoo, but I cant' seem to get LTE. It only picks up on 4G. I did a speed test and only get about 9Mbps instead of the 20+ on LTE. There is LTE coverage in my area, as I have another G2 on Telus that has no issues. I've attached the APN screens below.
Any suggestions?
Photo of Shawn McDonnell
Shawn McDonnell
Posted 3 years ago
In settings... Wireless and networks... More... Mobile networks...
Is network type set to lte/wcdma/gsm?
Play around with that setting to be sure lte is turned on. Lots of phones have it off because it used to devour batteries.
Also can you post a screenshot taken with your wifi off? Thanks.
Photo of Jonathan I
Jonathan I, Mobile Master
  • 114,364 Points 100k badge 2x thumb
What's the model # of the G2 you're using? Some of the models localized for Europe or other foreign regions won't have compatible frequencies. You need 1700/2100 for LTE.
Shawn McDonnell
It's the G2 (D803) CDN variant. I just tried Chad's suggestion and that did the tirck. It wasn't set to LTE/auto, just the GSM / WCDMA auto. Thanks all for the help and suggestions.
Photo of Jonathan I
Yeah, that would have affected it. You're good to go.
