LTE DOESN'T WORK.Maybe koodo can activate this or not?
  • Updated 2 years ago
I just changed to this new plan 40$/month and i have a problem when i activated my LTE it doesn't work.Can koodo disactivate and activate this option?
Photo of Hamzah Bakar
Hamzah Bakar
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
No, it's not something Koodo activates, Hamzah, it depends on the phone and location whether you have LTE or not.
Photo of BobTheElectrician
BobTheElectrician
  • 61,344 Points 50k badge 2x thumb
If you have any data working at all (3G & your email and browsing works) the service is not something that Koodo can switch off and on on their end.
Check your mobile network preferences to see if LTE is enabled or if the phone is limited to WCDMA/GSM.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,538 Points 100k badge 2x thumb
If you mean data in general then some ppl switching to accounts that have data included have found that their account has a data block on it so log into your self serve online and check under plans and add-ons that you don't have a data block placed on the account.
