LTE data issues
  • Updated 3 months ago
I live in prince albert saskatchewan and i've had incredibly slow internet speed with my LTE mobile data it took me a minute and a half to o search something on google, does anyone else have this problem? this is my first impression with koodo and it is not good
Photo of spencer the butt pirate
  • 90 Points 75 badge 2x thumb
  • frustrated
Posted 4 months ago
Photo of Camilo_A
  • 30,138 Points 20k badge 2x thumb
Hi there!
Reception looks above average  for your guys at Prince Albert... Are you using an Unlocked Device or a Koodo phone?
Have you run a test to see the speeds you get?
i just recently got a 2 year plan with koodo on a galaxy s8 plus on black frida. i have not run speed tests i just noticed my data not working and was curious if anyone else having this issue
Photo of Camilo_A
  • 30,128 Points 20k badge 2x thumb
Oh Cool!! Enjoy your new phone...
Run a test to see how it goes, also check coverage Map to have an idea about reception you should be getting since definitely out of Town might vary... If issue persists, you can troubleshoot with tech support.
Photo of Dinh
Dinh, Mobile Master
  • 21,928 Points 20k badge 2x thumb
How was your Koodo signal? how many signal bars did you have?
ive had mostly full bars where im at in town if not full it is usually 4 bars
Photo of Dinh
Dinh, Mobile Master
I would suggest you restart your phone & network settings and see if it can help. Also you could come back to a Koodo store and see if they can provide any advice, or call Koodo as Camilo suggested.
Photo of Phil French
Phil French
  • 72 Points
One thing I know from personal experience and my families experience is that in some small towns that have great 'coverage' according to coverage maps, the service isn't so great all the time. My mother lives in Denwood, Alberta and lives right in middle of the coverage area but can ONLY get decent reliability from her service when everyome else is sleeping, like between 1am and 7am. This is because although there IS coverage there, companies do not want to invest in many towers in areas where they don't have many customers and thus everyone is forced to share only one or two towers which causes network congestion and slow speeds.
Photo of Robert
Robert, Mobile Master
  • 101,130 Points 100k badge 2x thumb
I don't think koodo has speed problems
PS : I used 100MB of data to test that. What the...
Photo of Dinh
Dinh, Mobile Master
  • 23,602 Points 20k badge 2x thumb
Poor guy, time to upgrade or move to QC
Photo of David
David, Mobile Master
  • 83,290 Points 50k badge 2x thumb
Since they complete a Speed test by uploading and downloading a large enough file to do a calculation, did you really expect less?
Photo of Daniel Hryb
Daniel Hryb
  • 3,630 Points 3k badge 2x thumb
Spencer, I work in PA, and live close to Wakaw. I have no speed problems at all.  I would check your APN settings just to make sure they are set correctly.  I remember one time when I got the Note 4 brand new the APN setting were incorrect and I was not able to get LTE, only 4G. As soon as I got the correct settings I was getting LTE speeds
