LTE advanced supported for Kodoo Customers?
  • Updated 1 month ago
Hi Guys,
I am thinking of switching to Kodoo from Public and the only reason I would want to do that (other than the $100 credit) is that I think you guys offer LTE Advanced while Public doesn't. Can you guys confirm if you provide LTE-Advanced to Kodoo customers and what bands does my phone need to support to handle LTE+?
Photo of Josh
Posted 1 month ago
Photo of Dinh
Dinh, Mobile Master
  • 23,602 Points 20k badge 2x thumb
hi Josh,
Which phone are you using? I think koodo/public mobile are using the same network of LTE. The LTE-A requires compatibility check between your phone and the network. Make sure you are using a compatible phone and in a LTE-A coverage.
According to this:  you can use LTE-A on almost all LTE bands (4,7, 2..) except band 5.
Photo of Bernard
Bernard, Official Rep
  • 71,048 Points 50k badge 2x thumb
We do support it Josh. It was written up here well. If you go on our coverage page you will see the areas where it's available.
