Low cell signal at house
  • Updated 1 year ago
I get very low signal at my house. So bad that I cannot make phone calls because the service gets dropped. I may have to change companies. Will Koodo supply a signal extender? I am within your coverage zone.
Photo of Mike
Mike
Posted 1 year ago
Photo of David
David, Mobile Master
  • 93,400 Points 50k badge 2x thumb
No, but you can buy one yourself. Coverage is not guaranteed, event within the mapped (approximate) coverage zone, due to the physics of radio transmissions.
Telus offers Wi-Fi calling for iPhone users, which may be a better solution than buying an amplifier.
Photo of Mike
Mike
I can buy one myself!  These masters are good!
Photo of Jru Gordon
Jru Gordon
  • 9,144 Points 5k badge 2x thumb
Or there is also the option of moving!  I'm joking.  What kind of phone do you have, maybe my suggestion below will help!
Photo of David
It's free advice. If you want the $60 / hour advice you might receive a different answer (or not).
Photo of Jru Gordon
Jru Gordon
go into your cellular settings, look for something that says "preferred network", and see if LTE/WCDMA/GSM is checked.  If it is, uncheck it and leave 3G or WCDMA/GSM checked.  That might improve your signal.
Hope that helps!
Photo of Mike
Mike
Thanks for the advice! I will check that out.
Photo of Mike
Mike
I have the iphone 7.  Can't find the "preferred network" in cellular settings.  However I did find Cellular data options and "enable LTE" was on.  Should I turn that off?
Photo of David
  • 88,396 Points 50k badge 2x thumb
You can try turning off LTE in that portion of settings, which will force the phone to 3G.
Photo of Allan
Allan, Mobile Master
  • 61,910 Points 50k badge 2x thumb
Take a look here and see where the closest tower is to your house. You can decide from there wether it be best to get a signal extender, go with another company, etc.
http://www.ertyu.org/steven_nikkel/cancellsites.html
Photo of Lloyd Willett
Lloyd Willett
  • 3,688 Points 3k badge 2x thumb
Can anyone recommend a good home cellphone home booster from ebay or Amazon that works for telus/koodo and share the link i live quite away from the cellphone tower but get 1bar depends where i stand in the house if i get up on the roof probably get two bars
Lloyd Willett
Photo of Ivan
Ivan, Mobile Master
This one seems to be the most affordable option that's well-reviewed:
https://www.amazon.ca/zBoost-YX545-Signal-Booster-Office/dp/B003VOW5WI/ref=sr_1_7?s=wireless&ie=...
However, you do need to be able to place it somewhere that does get good reception in the house. If you have no such spot, then no booster will help you.
Photo of David
  • 93,238 Points 50k badge 2x thumb
I would also consider buying it with the Yagi antenna option.
However, $300 plus will buy a lot of months of Telus service with Wi-Fi calling.
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
@Mike: If you get good cell reception on Koodo's network outside, but poor reception indoors, then a booster is your best bet. Best option would be a serious one where one antenna is outside (or in your attic), then the other antenna (connected via coax to the first one) is on your ceiling (or indoor wall).
You should get at least 3 out of 4 bars outside for reception, otherwise wifi calling may be your best bet.
As an alternative to Telus (and their expensive plans), you could register your number with Google Hangouts. Using the Hangouts Dialer app, you can make outbound calls (unlimited Can&US calling) using your Koodo number for outbound call display. Mind you, this won't cover inbound calls.
Photo of rikkster
rikkster, Mobile Master
  • 68,238 Points 50k badge 2x thumb
WeBoost formerly Wilson Electronics offers cellular signal boosters.
https://www.weboost.ca/
https://www.amazon.ca/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=weboost
Placement of the outdoor antenna is key. This is how the signal is brought into the booster and thus amplified throughout your home. The fact that you have one or possibly two bars to work with is a good start. I've installed two older model Wilson boosters a few years back that are still working to this day.
Choosing the right antenna: Omni-directional antennas provide 360-degrees of coverage which helps if there are multiple cell towers nearby. Directional (Yagi) antennas focus on a narrower field, (45 to 90 degrees), allowing this type of antenna to reach farther than omni-directional antennas and pull in more signal.
Directional antennas are recommended for remote, rural areas provided that you know where the nearest cell tower is located, (see Allan's link above). As the name implies, a directional antenna must be pointed in the direction of the cell tower.
The price? Not cheap. Best to look at this as an investment that will pay for itself over time. If going with Ivan's suggestion and as David advises, I would look into getting the optional Yagi antenna. The higher the dBi, (or antenna gain), the more efficient the antenna's performance and the farther the range of the antenna will operate. Two versions are offered (11 dBi & 15 dBi).
https://www.amazon.ca/zBoost-YX026-Directional-Outdoor-Antenna/dp/B001CTJIK6/ref=pd_bxgy_107_2?_enco...
