lost phone, need pin#
I want to turn my line off bacause my phone got stolen, but I cant remember my pin, how would I get my pin#?
Photo of Matthew Collins Davidson
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Signing your self serve account and you can suspend your service there
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
If you forgot your password to login, click "forgot password" on the "Login to Self Serve" page.
Or call customer service at 1-866-995-6636 or dial *611 from your Koodo phone and tell them you forgot your Pin #. They will ask you multiple questions to verify you as the right account holder. Then they will reset your Pin#. (they can suspend your phone too)
Photo of Myke
Myke
Koodo will also flag the phone & sim card as stolen, so if someones tries to use it, they won't be able to.
Photo of koodomob
koodomob
  • 60 Points
Have you forgotten your phone security pin ? So, do you want to change your phone password ? What kind of mobile do you have ? First of all, try default security codes. If the codes are not working, get Master reset code to reset your phone . You can get it from the provider http://www.unlock-free.com/ to break code from your phone . Here, they provides code for old model Nokia and Alcatel phones . After resetting your phone password, you can change new password by using your phone settings .
Spam and off topic
