Losing ring tone on Samsung Core
My partner has been finding his phone settings change to no sound without his changing them. Calls go missed because of a lack of ring tone. Any ideas why? Possible fixes? Thanks for your consideration.
Photo of frananddave
frananddave
  • 992 Points 500 badge 2x thumb
Posted 3 years ago
Photo of rikkster
rikkster, Mobile Master
  • 68,252 Points 50k badge 2x thumb
Is it possible Blocking Mode was inadvertently enabled? This setting will block incoming notifications including the phones' ringer if set. You can access this mode by going to Settings > Blocking Mode, set the sliding switch to the off position to disable.
frananddave
What happens is that Dave sets the ring to sound and the volume and somehow the cellphone reverts to no sound.
frananddave
But thanks Rickster, we'll take at that. Notification sounds other than the ring tone have been an issue.
