Looking to get a plan for my Photon Q. Does Koodo have anything compatible with the phone?
I
Photo of Adrien D
Adrien D
  • 132 Points 100 badge 2x thumb
Photo of Daniel Kim
Daniel Kim, Mobile Master
i just checked the network frequencies on that phone and yes it will work on koodo's network but make sure you have it unlocked.you can pick any of the koodo plans. :)
Photo of Adrien D
Adrien D
Just to be sure, it would work on which frequencies? As there is no SIM card slot. So CDMA?
Photo of Daniel Kim
oh its a cdma device? then no it will not work, Im sorry :(
Photo of Jonathan I
Jonathan I, Mobile Master
I'm guessing this is a Verizon phone because it says that it has both CDMA and HSPA 850/1900/2100... But if there's no SIM slot then you're out of luck.
