long distance incomming calls
  • 2
Does it coast you long distance if long distance calls you?If so how much does it coast to get canada wide calling?
Photo of jessica
jessica
  • 80 Points 75 badge 2x thumb
  • 2
Photo of Ahmad
Ahmad
There is no such thing as long distance incoming calls. As long as you receive the call while you are in your local calling area, it is considered a standard local call. If you have a Canada-wide plan, you can receive the call anywhere in Canada.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,062 Points 100k badge 2x thumb
The only koodo plan without canada wide calling right now is the $45 city koodo plan, so you can get canada wide calling for anything from $20 to $60 a month, depending on what minutes and data you need.
Photo of PD
PD
  • 6,798 Points 5k badge 2x thumb
Any incoming call only cost you, when your minutes are over in particular month. That means if you have a $25 plan, 100 anytime minutes and you used 100 minutes then you will get billed for extra minutes used. Koodo extra minute charge is 45 cents per minute.
