Can I make long distance calls without adding the LD saver?
  • 2
  • (Edited)
Can I make long distance calls without adding LD saver, and if yes, how much does that cost per min? Particularly for calling Africa.
Photo of Claudelle Calfat
Claudelle Calfat
  • 80 Points 75 badge 2x thumb
  • 2
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,242 Points 100k badge 2x thumb
The LD saver is required to call any number that requires an international dialing prefix (i.e. 011).
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
No you need the LD saver to be able to make international calls. With it you'll be paying 15cents a minute LD fee to call South Africa
http://help.koodomobile.com/coverage-...
Photo of Shan Micheal
Shan Micheal
  • 150 Points 100 badge 2x thumb
Hi Can I use Long Distance (add on) as a prepaid customer?
Thanks
Shawn
Photo of Ashley
Ashley
  • 51,386 Points 50k badge 2x thumb
Hey Shan, great question! The LD Saver is not available for prepaid customers at this time. To make an international call and Canada-Wide call, you'll need to add a Talk Booster to your account. Just a heads up, a one minute international call deducts 5 talk minutes. Hope that clears things up!
Photo of Nicole Otieno
Nicole Otieno
  • 194 Points 100 badge 2x thumb
I was actually wondering about this too. I make calls back home (to Africa) a lot and was wondering if I would be charged long-distance fees. I am also a prepaid customer and I have the $25 Talk Booster which gives me 500 anytime minutes. From what you're saying ^^ all I need to worry about is the minutes being subtracted from my plan? I won't be charged long-distance fees on top of what I'm already paying per month?
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
From Koodo's website:
You can also use your Talk Booster add-on to make calls outside Canada. Anytime minutes will be deducted as follows:
1 min call from Canada to a U.S. destination will deduct 2 mins
1 min call from Canada to international destinations will deduct 5 mins
https://www.koodomobile.com/prepaid-plans
So there is no extra long distance charge on top of your prepaid plan.
Photo of Andrew Z
Andrew Z
  • 72 Points
I am a prepaid customer and need to call the U.S. I have a Talk Booster on my account.
Why can't I purchase an LD booster? Are calls to the U.S. not considered long distance? If LD booster is not available, how much are my calls to the U.S. costing me?
Thank you,
- Andrew
Photo of Andrew Z
Andrew Z
  • 72 Points
Got it. Thanks Paul. 'Preciate it.
Nicole Otieno
Photo of Laura Smail
Laura Smail
  • 190 Points 100 badge 2x thumb
I have the 50.00 a month plan and in Alberta, and would like to call to the United States, and or text there, mainly Ohio. Is North America  considered international?
Photo of Mayumi
You can text to the US without extra charge as long as you are in Canada.
If you make calls to the US:
Pay-per-use rate is $0.50/min
With Int'l long distance saver($3/mo) rate is $0.05/min
There is the U.S. Unlimited ($10/mo) add-on if you make many calls.
http://help.koodomobile.com/coverage-long-distance-and-travelling/long-distance
