long distance
If I have $39 plan with koodo do I have to pay if I go out of city?
Photo of Daria Nikiforova
Daria Nikiforova
Photo of Angelea Leaming
Angelea Leaming
  • 964 Points 500 badge 2x thumb
Not unless you make phone calls while out of city, You get up to 300 anytime minutes. If you are in city and make calls that are long distance you will get charged.
You have unlimited nights and weekends starting at 5pm so try to do your calling after 5 pm.
Photo of Jonathan I
Jonathan I, Mobile Master
No actually all plans since approx. October 2011 are Canada-wide. This means no long distance or roaming charges in Canada. The only thing you need to worry about is airtime.
Jonathan I is right Daria, Canada Wide means you can go anywhere and any call is always local. Sweet!
Daria Nikiforova
thanks guys.. i was worry because now I'm out of town and when I try to call it says "long distance may be required"
Dial a one first. Tells the system that you're aware that you're calling outside your local area. Still no extra charge.
