Long distance
  • Updated 2 years ago
I have a 500 minute plan...but every time I try to make a call it says "long distance charges will apply"... I thought the plan included canada-wide?
Photo of Jessica R
Jessica R
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Bernard
Bernard, Official Rep
  • 80,832 Points 50k badge 2x thumb
What name is the account under Jessica? We could look at your plan to confirm.
Photo of Mathieu
Mathieu, Mobile Master
Hi Jessica,
Even if you have a canada-wide plan it will tell you that if you don't dial 1 ahead of the long-distance number. Take a look at your plan details, you will see if it is Canada-Wide or not.
Photo of stillgolfing
stillgolfing
  • 1,924 Points 1k badge 2x thumb
Jessica: Are you sure it said "will apply"? My wife & I have the Canada Wide Plan and when I'm in the "Man Cave" and I call her when she is on the back deck (so basically we are 75 ft apart) the Koodo Message says "long distance charges may apply". Happily they never do!;))
Photo of Goran
Goran, Mobile Master
  • 96,388 Points 50k badge 2x thumb
That's what it's supposed to say as a blanket statement for all plans. "May apply."
Photo of BobTheElectrician
BobTheElectrician
  • 66,738 Points 50k badge 2x thumb
The call IS indeed long distance, but it's up to your plan to see if it's included in your normal minutes or charged as an extra.
stillgolfing
Hey, Bob! What about when I call my old dad in Victoria B.C. (cell to landline 3000 miles away) and there is no message. Is that Local then? Just asking. :))
Photo of Mathieu
Typically you only get the message when you don't dial 1 ahead of a long distance number.
