long distance call in the us for a month
  • Updated 11 months ago
Hi , in the next month I will have to make a lot of calls to the us , I'm in canada, can I add on long distance calls in the us, but just for one month ?
Thank you
Photo of Dominique D'Amico
Dominique D'Amico
  • 80 Points 75 badge 2x thumb
Posted 11 months ago
Photo of Dennis
Dennis, Mobile Master
Yes.  You just need to remove the add-on when you no longer need it
Photo of titaniumtux
titaniumtux
  • 12,912 Points 10k badge 2x thumb
If calling the US is frequent, for the call quality, it'll likely be worth the $10 per month for the add-on which can be removed any time.
Mind you, after doing SMS validation with Google Hangouts Dialer, you'll get unlimited Canada & US calling on wifi or data. I find call quality on Google Hangouts Dialer to not be as good as cellular voice, but for the occasional call, it's plenty fine for many of us.
Dominique D'Amico
Thank you
Can you send me the exact link for the add-on?
Thank you kindly
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Log into self serve > View rate plan > Add-on Manage > U.S. Unlimited
