Long distance call?
I have a Blackberry Curve 8530 and when I try to make a local call, it tells me that I am trying to make a long distance call. What's wrong?
Photo of Frank Côté-Robin
Frank Côté-Robin
Photo of Chris Petersens
Chris Petersens
Have you called that same number before and it was local? Maybe the "local exchanges" have changed where you live slightly. Do you have a Canada wide plan with Koodo? If yes, than long distance doesnt matter anyways. All calls those plans are local. You may still hear the announcement/notification that it's along distance call bu there is no extra charge for it.
Frank Côté-Robin
Well the problem is, sometimes it tells me it is a long distance call, sometimes it doesn't and works perfectly fine without the automated message. I really don't understand what's happening. Thank you for your reply.
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
The automated message is in your phone system. So your phone gives you a warning when it recognizes your call as long distance. (because your phone doesn't know what plan you have - like Canada-wide)
Maybe you receive this message because you made a call from different area...?
Frank Côté-Robin
The thing is for the 3 past years, I called my mom and it never told me that message. Since last week, it tells me that message now and then and I am calling from the exact same location as last year for example. I called technical support but they don't know what's wrong and I hope it's not someone who ''stole'' some ID I have and use my number from somewhere else. I don't want to pay for usage I have nothing to do with.
Photo of Jordan
Jordan
  • 2,820 Points 2k badge 2x thumb
nope that can't happen. Your sim card is locked to your account and to your phone. If someone were to steal your account/ID/sim card.. your phone would not work anymore. The question was asked before, do you have a canada-wide plan?
Frank Côté-Robin
Yes I do have a Canada-wide plan and I know I would not get additional fees for dialing 1 before. However, I'm curious and I would like to know why I suddenly need to dial 1 before a local call. It is weird and I don't get what's happening.
