long distance add on question about US
  • Updated 8 months ago
My parents are in Florida for six months of the year.  I usually put a long distance for the US on my phone for those six months.  Is the unlimited US for 10 dollars a month gone and it's just 1000 minutes left?  A little confused on how the area codes works,  is it just for the area codes mentioned?  559-726, 712-775, 712-432, 605-562, 605-475, and 530-881.   It's just these area codes that are not included correct and not area codes mentioned in between?
Photo of Falcon
Falcon
  • 452 Points 250 badge 2x thumb
Posted 8 months ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,706 Points 100k badge 2x thumb
Correct on both counts.
Photo of BobTheElectrician
BobTheElectrician
  • 67,672 Points 50k badge 2x thumb
Consider signing up for a VoIP service which typically does not cost a premium to call anywhere in North America. You can then use WiFi to call your folks, and if you pick a convenient US number for your VoIP plan, your folks will not have to pay long distance to call you.
