lollipop is ruining my nexus 4!!!!!
I have had my nexus 4, purchaced on tab over a year ago. Recently, it underwent an "upgrade" to lollipop and effectively turned my once top knotch phone into a total pos. It shuts down randomly, freezes up like my old nexus s under the simplest of multi tasks. And generally struggles with everyday calling and texting. I want my old phone back!!! Is there anything I can do? Please help me koodo. Thanks, Andrew. Ps, I can't afford another new phone!!!!!
Photo of Andrew D. MacDonald
Andrew D. MacDonald
  • 236 Points 100 badge 2x thumb
Posted 3 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 67,100 Points 50k badge 2x thumb
A month or so ago this board was being overrun with folks desperately needing the 5.0 upgrade or they couldn't sleep at night.
May cost you a night's sleep, and don't ask me, I haven't tried it, I don't blindly do automatic updates:
http://www.gottabemobile.com/2015/01/...
That type of link doesn't look like it will last long.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,130 Points 100k badge 2x thumb
Why exactly did you link to a story about the sling box Bob?
BobTheElectrician
"That type of link doesn't look like it will last long. "
They churn thru topics fast. So good to hear from you again.
Photo of matthew sider
matthew sider
  • 746 Points 500 badge 2x thumb
Way he can link an story is not a big dale way is it this happens to good people Plsese keep in mind
just my opinion. .
BobTheElectrician
This may please the lab coats better:
Have you done a simple factory reset of your device, it should fix all your issues
First it's a Nexus device which is a developers tool not a regular device from Samsung or Motorola ect and has always been to test updates and they are known for this. Next you are asked if you would like to update you are never forced to. Then If you have issues with an update Google supplies the tools to roll back the Nexus devices to a previous version of Android.
I always do a factory reset after every big update on every device and never had a single issue. Simply back up your info to your Google account and then simply sync when your setting your device back up, it's easy and removes the possible issues of apps that haven't been updated for the new version your installing that you may have had installed prior to updating.
matthew sider
I'm confused about this group??
What's confusing Matthew?
matthew sider
I tray get help on my contact. information was lost on my goolge. account but I didnt get help on this not the first time I didn't get help at all
Is being os please I need help getting lot of sync error way is this happening to me not first time on kookdo phone now I know is not kookdo falt I get it
but in store level send for repar not first time??
BobTheElectrician
Once you get the contacts straightened out,
http://www.wikihow.com/Export-Gmail-C...
if you have access to a computer. You will at least have a backup.
Photo of rikkster
rikkster, Mobile Master
  • 68,252 Points 50k badge 2x thumb
I didn't see it mentioned, here's the link to the Nexus factory images. You'll be looking for the heading: "occam" for Nexus 4, if you decide to revert back to KitKat.
https://developers.google.com/android...
