locked iphone on telus wont work with koodo
I got a used iphone 4s locked telus from a friend and i thought koodo and telus where together so i thought it would work i my friend doesn't know the original owner is there any way to unlock it or use koodo
Photo of Brendon Hink
Brendon Hink
Photo of Daniel Kim
Daniel Kim, Mobile Master
I thought telus iphones worked with koodo without unlocking. You might want to call koodo and see what you can do before actually unlocking.
Make sure you put the sim in correctly also.
Brendon Hink
If i look at carriers it says rogers wireless, koodo and bell? not telus
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Make sure if it is a TELUS iPhone that you have the Koodo APN settings not the Telus ones. If it is a Rogers iPhone then you need to unlock it and then put the Koodo APN settings into the phone.
Brendon Hink
APN? i looked around all i see is VPN
I think you have to do it through iTunes
Sorry I'm an Android guy personally so I'm just going from what I remember being said here. Search the forum or You Tube on how to change APN settings on iPhone & I'm sure you'll be able to figure it out.
Photo of Daniel Kim
Yep make sure you update the carrier settings
Photo of Myke
Myke
Guys, the APN has zero affect when it comes to the phone connecting to the network. The APN is only needed for a mobile data connection.
You still need the APN settings to make the phone work as in Data yes but it's still needed ;-)
Brendon Hink
i think my iphone is on rogers or bell but i dont know
Photo of Daniel Kim
If you are on rogers or bell you will need to unlock your phone. To check go to settings>about>carrier.
Brendon Hink
it say rogers wireless and bell
The phone can only be locked to one carrier so it wouldn't be Rogers & Bell just one or the other.
You'll need to get it unlocked if you put your Koodo Sim card in and it doesn't work. You can try somewhere like Cellunlocker.Net or gsmliberty.com and buy an unlock from them.
Photo of jhuio
jhuio
  • 90 Points 75 badge 2x thumb
Hi you can easily unlock your iphone4s by using remote unlock method. If you need remote unlocking service you can visit this site http://www.simpleunlocking.com/apple-... here you can get the service and unlock your iphone4s easily. After unlock your iphone4s you can easily swap to any other network.
Photo of Robert
Robert, Mobile Master
  • 103,928 Points 100k badge 2x thumb
This thread is kinda old...
Photo of Ivan
Ivan, Mobile Master
Plus that was spam.
