Local calls when I am not in my own city
If I make a local call in another city, where I am not living, will I be charged long distance? That is, I live in Victoria, but will be located in Saskatoon, and making a call in Saskatoon. Is that called a local call? I am on prepaid, so I pay $25 for 500 minutes.
Photo of Marlene Lavallee
Marlene Lavallee
  • 246 Points 100 badge 2x thumb
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
Local outbound calls are calls made within the local area you're located at the time of calling. So if you're in Saskatoon calls made to Saskatoon numbers are local, but to your home city will be long distance.
Conversely, if you receive a call from anywhere while you're outside your home city, it will be long distance.
Photo of Sophia
Sophia, Mobile Master
True! However, in either case your calls just use one booster unit, no matter where you are in Canada and no matter where the call is from :)
Marlene Lavallee
Thanks.
