local call or long distance call
I'm a newcomer in Edmonton, and just buy prepaid sim from Koodo. I have 15$base plan plus Booster for call 500 minutes, but I wonder which destination for call is considered as long distance? If I want to call my friend in Ontario, Toronto, If it will be considered as long distance or local call? Thank you.
Photo of Piyarat Samantarath
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Piyarat,
If you made a call to Toronto from Edmonton the phone call will be long distance. Keep in mind that the Booster for minutes is Canada-wide so you don't need to worry about it using up your minutes faster as it is a designated $0.05/minute regardless of where you call in Canada.
On the prepaid page on Koodo it explains a few more details in regards to how phone calls work in regards to your Booster, I've provided a link below for you to have a look at.
http://koodomobile.com/en/on/plansand...
Hope that helps :)
Thank you very much for your kind assistance. You clarified me a lot. Have a good day.
